I am thinking of running the Comp cams Magnum 305H with 585 lift and 305 dur. My question is will this cam poke the valves through the flat tops or will they clear ok. I don't want to remove the heads to clay the pistons, so I was hoping someone has this combo running. 351C open chamber 4V heads, flat tops with .080 recessed tops. thanks.....Bob
