Can the glass rear window be reglued to the zippered material? My 92 GT convertible is missing the rear window and I found one at the pick a part but it is delaminated from the top material.
Mike
Discussion Starter #2
Well a little googling and came up with 3M Windo-weld and glass primer seems to be the ticket. Some people even used high strength double faced tape with success. Might have to give it a whirl.
Mike
A new one with zipper don't cost that much....
And will last a long time...
Double check direction zipper/slider open and close ...
Depending on manufacture and year as they will be different .
Compare zipper to the one in your top already...
You may have to take new one to upholster and have re sewn
To match up to old.. Verify teeth size also.....
