Someone has modified from original automatic to manual choke using a cable on a a FE engine with original 2100 carb?
Ive mounted headers and there isnt any place to fasten the heat tube. Modifying to manual choke is an alternative
Have started the car 2 times after the headers and and dual exhaust system was installed, but the engine was very difficult to start. Had to push the gas pedal 10-20 times and the engine hesitates a lot from idle to higher RPM. Cold weather, summer petrol and defect choke could be the reason
