Yeah, did it to my fastback. Im happy with it now. I used the conversion thing that uses the old steering link. Im happy with it. Works well. The steering is real responsive with the close ration box
It is pretty easy to convert. I just converted to power. All you have to do is diconnect the hole steering assymbly from the pitman arm. and then put on the Manual steering assymbly. But the steering box for Power has diffrent ratios than the one for manual steering. You can use the steering box for power steering but it will be very hard to turn the wheel. Its not recomended.
