Hey guys, I am attempting to build a motor and need some advice. I will provide all the engine facts and let you guys answer the question...
-68 Date Code 390 FE rebuild in the past and bored .010
-In the rear the oil galleys are plugged, which leads me to believe I have mechanical lifters and solid cam
-It will have full length headers
-Mallory Ignition
-C8AE-H heads ported & polished
-Edelbrock intake
-Holley 750 Carb w/ Vacuum Secondarys
-C6 automatic Transmission
-Stock rear end
I want to purchase an Edelbrock 2106 Hydraulic Cam and Lifter set (found a set for a good deal) and want to know if all I need to do to use this set is remove and replace the current cam and lifters and simply remove the oil galley plugs to allow oil to get to the lifters, or is the process way more difficult then that?
-Mallory Ignition
-Edelbrock intake
-Stock rear end
