1 - 15 of 15 Posts
If I wanted to convert my roller c4 trans into a 4x4 c4 trans do I just need a different case and rear shaft?
What all will I need?
Cool, so I can keep my case
Now I just need to find a tail housing and shaft, already using a deep pan.
On 2005-01-13 16:14, 64 TBOLT wrote:
find a early BII or ranger. Heres a C5 from one
That tail shaft is different if I remember, however you could run the BII or Ranger T-case...
If you want the Early Bronco Dana 20 T-case, you need the EB C4 parts.
right,but he didnt say what t-case he is using
<font size=-1>[ This Message was edited by: 64 TBOLT on 1/14/05 5:59am ]</font>
Discussion Starter #7
Humm, I didnt know I had more than one to pick from.....
What would be the better transfer to use with a c4 and how do I go about identifing it? I plan on using the vechicle for more of a crawler/ low speed cruiser than a mud bogger.
the only t-case that came behind a C4 was a Dana20 from the early bronco.Then when the BII came out in 83/84 they had a C5 tranny with a 1350 manual and electric.Out of the two the D20 is the strongest,its cast iron where the 1350 is aluminun.
<font size=-1>[ This Message was edited by: 64 TBOLT on 1/14/05 3:00pm ]</font>
Discussion Starter #11
thanks a bunch
What would a good transfer case be for a c6? And would I just need a new tailshaft and rear adapter for that also?
<font size=-1>[ This Message was edited by: fogged408w on 1/14/05 5:52pm ]</font>
for the C6 the strongest t-case is the NP-205. You need the short rear shaft and the t-case adapter.now theres two different length shafts,i dont know the lenghts of them,but heres a pic ot the two adapters
You should start your own thread. This one has been out of commission for over 10 years.
Include what year, engine, vehicle.
1 - 15 of 15 Posts
