I am just about at my wits end. I have a modified 88gt mustang. My mods are as follows:
347 stroker kit from Coast High
Edelbrock Performer Heads that have been worked
Trickflow Track Heat intake w/ 70mm TB
AOD with 3000 Stall and Shift Kit
3.73 gears
24lb injectors
trick flow cam (mild) if I remember 221/225 .499/.510 ? also have 1.7 roller rockers
These are not all of my mods but just trying to give you an idea of what I have.
My issue is COOLING or lack thereof. It does't matter if I am sitting still or running 75 down the interstate.. it doesn't cool very well at all. I even have a friend at Ford, built my motor and tranny, very sharp guy who has pretty much the same problem and we need a solution. I almost said affordable but, at this point I would be willing to pay whatever just so I can cruise and not worry about overheating.
We both put in Granatelli aluminum radiators --- 3" thick, 38" wide, 1.25" extruded aluminum cores.
We both have tried a series of different thermostats( 160,180) and cooling fans. I currently have a 160 degree thermostat with the Flex-a-lite Black Magic EXTREME. This is their mack daddy cooling fan. Suppose to move like 3600-3800cfm. I have tried the water wetter, tried cooldex to see if it cooled better. Just don't know. I've heard my thermostat is too low and the water doesn't stay in the radiator long enough to cool. I need someone with greater resources than I have to give me a solution. Please help.
I'm sure someone has a combination that works. BE Cool has a kit, Radiator, Cooling fans (Dual) but I think it is over $1000.00. I have considered pulling off the Black Magic fan and trying to fit a Dual fan system in place. I heard SPAL has one for the mustang. Also, I am running a factor type water pump. Do you think one that moves more water would help?
Lastly, I have underdrive pullies in place which could explain the overheating while idling but like I said even when I'm going down the interstate, it gets what I would call hot. my temps in the summer with the A/c on are 230-240 while idling and 210 while going down the interstate. These figures are with the a/c on, which is a must in South Carolina during the summer. I have even heard the aluminum radiator may be an issue. I might try putting the factory radiator and fan on to see what happens. I just have invested a lot into the motor and don't want to warp heads or crack anything. I am really looking for a proven combination; water pump, radiator, cooling fan etc. that WORKS. Anyone who has dealt with and overcame this problem, I would love to hear what you did.
Andy
3.73 gears
24lb injectors
Andy
