Well I have already ordered all the cam stuff from crane, springs, locks, cam, retainers, etc., according to what they have as a "motorsport sytem" for my car. So it is supposedely supposed to fit together...
I am just wondering if anyone has any problems in general with crane, with springs not fitting or valve locks or anything not working or are they fairly reliable in compatability?
However, you must check that the springs fit the head properly, machineing MAY be required. Also, be sure there is clearance between the top of the valve seal(as installed) and the underside of the retainer..060, sixty thou, is usually considered minimum.
