I am looking at a crate engine with the carb replacement EFI thing, has ECU and stuff.
Not sure if it has the electronic fuel pump, but I can get that. And I know it will probably need a return line. etc etc.
The engine should bolt right in. Not like its a easy job.. But my question is how hard is it to put in the return lines, fuel pump etc etc. To retrofit into existing system? Was the return lined just tied or fastened next to the sender line? how about the connections at the fuel tank?
Really really would like to go with an EFI setup but questioning how much of a pain the retro fit actually is
