Does anybody have any pics of the crites aluminum rad install? 62 to 65 isnt it? I just want to see pics of the mounting hardware ect. Thanks
Rick
I've got their mount kit but not the rad.....I am not far enuff along to even try to install the mounts. The directions talk about cutting out a section of the strut support bracket that runs from the frame to the rad support.
But, very similar to the Ford mounts where the Ford mount saddles the tank to core seam. Then a flange to bolt to the rad support. On top is a U shaped aluminum piece about 12-14" long to hold the top of the rad.
Thanks strokin.
The opening must get bigger to then ehh? Ill screw around with it and fiqure it out, just thought if someone had pics I could be lazy
Yea, the instructions talk about cutting the rad support opening. I forget how much. I want to say equally on both sides and almost out to were the vents are on the passenger side and equal amount on the drivers side.
