Will this kit enable a 351W to be installed without difficulties.
Anyone done this mod? What engine you running? what other issues you had when you were putting the engine in? Will a 351W interfeer with the steering box?
Looking seriously at crate motors and why do a 347 when you can do a 427 stroker.. So anyone been down this road? What issues did you have to resolve..
Thanks in advance..
Installed Dart 9.5 block 412 c.i. Home made 3 step headers. Stock steering linkage. Modified shock towers, relocated both a arm's outboard 2". Used Alston adj upper's w/heim joint's and homemade cm lower's w/heim joint's. Stock ball joint's taken apart, cleaned, greased. Adjusted tie rod's longer without modifying them.
I have a bunch of pictures.
