1 - 12 of 12 Posts
I recently converted my 64 Galaxie from column shifter
to floor console shifter..:D
which turned out being more trouble than you can shake a stick at..:bicker:
You usually can find consoles and shifters on fleabay
and occationally linkage that connects floor shifter to shift lever on the Cruise-O-Matic...
but never the shift lever for a floor shift Cruise-O-Matic....
This is the point where thing starts to get dicey...
On a column shift,when in park shift lever on tranny points down in 8 O'clock position
But on a floor shift it points up in a 1 O'clock position...
So first thought is why not just disconnect lever inside tranny and turn to up position....
It does not work....
First of all it hits the floor...:eek:
because lever curves away from transmission...
On floor lever needs to curve in towards tranny in order to clear floor
and move it closer to center of transmission tunnel...
Secondly the ratio will be way off and shift points on indicator at console..
for example,when in park it will indicate R and when in low D1.....
Soo whats the solution???
Buy a shift lever for a floor shift tranny...if you can find one (not)
Buy a retrofit bracket... if you can find one(not)
Or make one your self...
Hours of ,cutting, bending,welding ,trial fitting
and trying to get bends lenghts & ratio correct....:bicker:
So every thing work the way it suppose to..
Neutral safty, Back up switch etc...
SO I'm just testing the waters here to see if there is any interest
in a retrofit bracket...
This is what i have done and if anyone out there is interested in buying..
I can make it and send it to you for $$60 Bucks...
PM me if interested......;)
Thanks Lars....:)
Discussion Starter · #2 ·
so what do you guy's think..any one interested??...:)
or am i wasting my time on this...:confused:
I would have thought more people would have wanted these. About once every 6 months someone is looking for one. Maybe the price is not what they want to pay or maybe they are making their own? I do recall you posting the plans for it.
i did post it ..;)
but its a real pain in the butt to get the ratio right though...:)
Maybe after they realize how big of a pain is they will realize how much they need your bracket.
Maybe the price is not what they want to pay.
yeah... you probably right..
figure material my time fabbing ,put in mailer go to post office
and send it of to whom ever...would be worth something..:confused:
  • Like
Reactions: nytling92
Seems like a great idea, not having to look for the shift lever to begin with and then have to open the trans to put it in. Unfortunatly it's one of those items you will have to wait untill someone has the need, either converting a coulmn shift car to floor shift or replacing a trans and winding up with the wrong shift lever.
Mike
Discussion Starter · #8 · (Edited)
Mike
you right Mike.. i do see the subject come up every now and then...so it seemed like a good idea....
i think i'm gonna make a copy of oem shifter linkage too
thats usualy also missing when you find shifter/conole...
that way i have one on hand ...
if any one is interested.....;)
Discussion Starter · #10 ·
Thanks Lars....:)
I need shifter [email protected]
Discussion Starter · #12 ·
im not making bracket anymore...
this was posted 10 years ago
use post img link to see how to make your own bracket..
1 - 12 of 12 Posts
