Does anyone know where to obtain a transmission dip stick for an FX Cruise O Matic (small case) transmission for a 1967 Galaxie? I’m new to this forum and just learning to use it. Thanks for any help.
Do you have one that you're looking to replace? The reason I ask is I needed to replace one on my '67 and found that there are two different lengths so you may need to measure your existing dipstick.
The MPC lists part number C6AZ-7A020-C as correct for the 66-68 FX transmission and it's approximately 23-1/2" long. My Galaxie has an FX transmission with a 1965 date code (maybe swapped out at some point?) and I needed C5AZ-7A020-A which is 19-13/16" long.
If you need the 23-1/2" dipstick you can find it here: Galaxie Dipstick
