I serviced the Cruiso on my 65 Galaxie 352 today. Drained all the fluid, new filter, 10 3/4 quarts of Valvoline Type F etc. Adjusted the bands. I adjusted the front band according to the manual. Released the lock nut, pulled the actuator arm back and inserted a 1/4" gauge block, tightened the adjusting screw to 10"lbs (I don't have an inch/lbs torque wrench so it did it with my fingers and a small screwdriver by feel very lightly), removed the gauge block and tightened another 3/4 turn, secured the locking nut while holding the adjuster screw in position. Now, the trans has a hard shift when shifting to reverse. I set the idle speed low, 500 rpm in gear, and it still hits pretty hard. I know the earlier Cruisos would crack the servo cover and sometimes the trans case because of this condition. I am thinking of dropping the pan again and backing off the adjustment. Any ideas?
