After I drive the car, short or long trip, if I open the hood I can hear the battery hissing/venting. There seems to be more corrosion than normal, greenish yellow crust around the battery tray and various places below the battery. It's letting off a slight sulfur smell too.
I clean the area off so nothing bad happens to the metal, and I've put a voltmeter across the battery while it's running and it was around 14 volts. It's got a 65 amp alternator on it and possibly the original 1968 external voltage regulator.
The corrosion build up seems like a problem to me, any ideas why this is happening?
