I've been reading some posts here and would like to post my combo here for your opinions / best guess-timates. This engine is almost finished, has not been fired off, will not see an engine dyno, might see a chassis dyno. The combination is my own so if it comes across as a little goofy there's no one to blame but myself.
351W, +030, 1976 block
Stock crank, .010/.010
Stock rods, polished on beam, balanced, fitted with full floating pins
KB Hypereutectic pop up pistons, 11.25:1
ARP Main stud kit
C.A.T. Main girdle
Melling HV oil pump
ARP Oil pump drive shaft
Cloyes double roller timing
Ford Motorsports SFI balancer
Ford roller bearing cam retainer
ARP Head studs
World Rousch Iron 200CC heads
2.02 / 1.60 Stainless valves
1.55 Dual valve springs, titanium retainers
Crane 1.6 aluminum roller rockers w/studs & guide plates
Delta Cams custom grind solid lifter cam:
Lift - I=575, E=572, Duration - I=308 E=317
Howards lifters, solid w/oil hole in face
Hooker Super Comp's 1 5/8"
Price Motorsports billet intake adapters w/ lifter galley cover screwed to block
Weiand 289/302 tunnel ram, modified
Enderle Bugcatcher mechanical fuel injection, #21 main, ported to intake runners, running on gas
Enderle 7GPM belt driven fuel pump
MSD Billet 'Ready to Run' ignition
C4 trans with Alto red clutches & valve body kit
Hughes 3500 convertor
TCI SFI flexplate
9" rear with 4.11 gears
Strange full spool, 33 spline
Dutchman 33 spline axles
29" x 10" x 15" slicks
Cal-Track traction control
Est vehicle weight 2900 lbs with driver & 8 gallons gas
Also 8 point cage and sub frame connecters
This is all in a '68 Falcon Futura.
Would any of you care to hazard a guess as to what kind of hp/torque I might see at the flywheel/rear wheels? How about et/mph?
This engine is 98% completed, just the final mods waiting to be done on the intake and then button up the top. I will not be changing any components at this time so you really don't need to tell me I need to change this or that. If you would like to tell me what you would do different if this was your motor then I'm Ok with that. Know what I mean?
Really looking forward to your responses.
Murff
Anybody can restore a car. It takes a real man to cut one up.
_____________________________________
<font size=-1>[ This Message was edited by: Murff on 3/6/06 11:12am ]</font>
ARP Main stud kit
C.A.T. Main girdle
Melling HV oil pump
ARP Head studs
TCI SFI flexplate
Murff
