just changed my main wiring harness in my 69 cyclone,now my car wont start.it can be jumped at the solenoid but the ignition wont work. i changed the ignition switch and the solenoid twice. my car is a 4 spd the harness was out of an automatic.i cant find a neutral safety switch.and dont think the 4spd ever had one.iam pretty sure this is the problem but not to sure how to fix it. helppp!!!
Find the neutral safety switch connector in the harness, and jump it (bypass). Typically a RED/LT BLU wire, but check you wiring schematic.
Beware it will crank at at any time in any gear and any clutch pedal position.
Discussion Starter #4
i would rather have it proper.where was the switch,and are they available to buy;with harness
