My plans for my high compression aspirated 408 build are coming together slowly but surely. I have decided to go for the AFR225 (saving hard), my problem is that I would like to make a cylinder head upgrade to my 302 that is still going okay until I piece together the 408, still running cast iron 302b heads with home-ported job, not flowed, oversized valves (chebby) etc. My problem is that the 408 will still take a while and the 302 is still running and I know it could go much better with the head upgrade but I just want to invest in one set that would be compatable for both set-ups.....would the 225's be too big for the 302 coz I was thinking that when I eventually get the 408 shortblock together I could just swap off the 225's from the 302....302 is 40" over, pop-up pistons (not sure of comp ratio but only runs 102.6 octane), cam is mild, not sure of exact specs, victor jr & 720 holley....Thanx in advance....ROBBIE.
