Hey, I've been considering buying new heads for my 65' Falcon. As it stands now, I have the setup in my signature with 71' D0VE heads, and a blown head gasket. I believe one of the heads may be warped, and will probably need to be milled if I wish to replace the the head gasket. The motor also has very high mileage, although it is unknown.
The plan is to possibly build a mild 347 stroker or 351W next winter for the car, but for now the head gasket needs to repaired. I was thinking about mabye buying the new heads for the engine now, and putting them on the 302, and over the winter building another motor and putting them on it.
My biggest concern though is buying heads that are too small for the windsor I'd build, but I don't intend to build it up too much. My car sees a lot of driving, and chances are this summer and next with the new motor I'll be driving it over 300 miles to school, and mabye back and forth to work in the spring
I've been considering mabye Victor Jr. heads or Performers/Performer RPMs.
I guess one thing I need to be careful of is combustion chamber size, I don't want anything over 10.5 compression for the next engine I build, so I should steer away from anything below 60cc. That sorta makes me lean towards the performer with the 64cc chambers. Also, I wanted to consider the angle and positioning of the exhaust ports. If I put a 351W in the falcon, clearance with the headers will be very close (may have to use manifolds), and I know some cylinder heads make it easier or harder to put headers on.
Please if you have any suggestions or ideas, let me know. Right now I"m just sorta playing around with this idea, but I'm going to have to do something soon about my head gaskets. Thanks.
