1 - 13 of 13 Posts
just curious about what my combo would make,heres the list of goodies
4.125x4.00
6.125 rod
9.5-1
.588/.612-243/255,112 L/S,solid roller
afr 205's stock
1-3/4 hooker super comps
8 psi boost roots holley 174
15 psi ati/vortech (intercooled)later on.
thanks guys.
is that holley blower going to be big enough?what intake are you using?
well im hping if i use the smallest pulley i can get 8 psi of SAFE boost,well see,its a 302 int,ive got the pme spacer kit,wich is a very nice kit i might add,i want to use this set up for know untill i get the coin for a centri s/c,ive had the blower sittin in a closet for 5 yrs,im puttin on a pretty good 5.0L first to get all mistakes out of the way,just so i can relearn on a centrifical s/c ive got to engines being built at the same time.
Those headers suck on the AFR 205 port. You should have bought FPAs.
Off the boost ~550HP. On the boost ~ 725-750HP.
Discussion Starter · #12 ·
yeah i didnt want a crazy cam to chew up parts esp valve springs,wanted the blower to make all the hp,wanted a street killer
I put down 476 hp / 528 tq to the wheels with a similar NA combo. Desktop dyno showed that a bigger cam didn't make much of a difference.
1 - 13 of 13 Posts
