what oil pan will fit a dart 9.5w block,want one with a windage tray built into pan,i dont think i can fit a convintional tray due to rods and throws,oh yeah its for a fox application.thanks guys
Do you have the Sportsman or Iron Eagle block.
The Sportsman will probably work with any pan you choose without mods to it.
The Iron Eagle with it's huge rear cap may need some work to get the pan to fit. I had to machine a large 45 degree chamfer on both rear corners to fit my pan.
Mine is a custom job from Moroso. It does have an expanded aluminum crank scraper built in. It also has the pass. side kick out to reduce crank windage. Be warned though, this type of pan probably will not fit most headers on the pass. side due to the kick out.
Check the Moroso catalog. I think they make this pan in steel that's available from Jeg's or Summit. I'll try and find the part #.
Ok, the pan #is 20532. Thats for a steel one.
The pickup is #24532.
Again, this pan has the pass. side kick out.
<font size=-1>[ This Message was edited by: 85mike on 6/7/06 2:11pm ]</font>
cool thanks for the info!how big is that actual kick out?i wound up getting the sportsman!(total lack of communication on my part and engine builder)
It sticks out past the block pan rail about 1 1/2 in.
That's enough to require mod's to one header primary tube of my Kook's headers. Cut and splice.
