Does anyone know which windage tray will fit the mains on a Dart SHP windsor block? I called Dart and the tech said that I need to use a cleveland type unit because the crank journals and mains are cleveland type. He didn't sound to sure of himself though.....I tried to find the info on the web but could not find much. Just trying to make sure I get the right one.
Banned
very easy question for you to answer
the main cap bolt spacing is wider on a Cleveland than a W . what is the bolt spacing on your Dart block ?
