PS: I have no instrument lights at all, but the gushes work and the indicator light works as well.
Matt
not positive but i think the fuse is on the out side of headlight switch.....
i would disconnect battery and remove HL switch ,,
check that coil spring looking thing on switch for bad contact/corrotion...
clean it of ...
my switch would only work every now and then...
i clean it up and now it works perfectly...
theres a black wire bolted to dash from harness,, and that provides main ground to dash/instruments etc.....
