I'm in the process of taking the dash out of my 63 galaxie to repaint it and I've hit a snag. Can someone explain to me how to get the ignition switch and the headlight switch out of the dash so I can finish pulling it?
Thanks!
CB , on a 64 disconect the battery pull the head light switch , under the switch there is a small button push it and pull the switch all the way out.Then un screw the trim bezel and remove the switch from behind. The ignition switch : put key on accs position insert a paper clip in to the small hole on the switch and push it in as you turn the key counter clock wise. Turn the Bezel and push it should twist off ( not screw off) hope this helps.
<font size=-1>[ This Message was edited by: sleepysal on 4/23/06 1:40am ]</font>
Thanks for the info! I'll give it a shot in the morning and see what I can come up with. Thanks again.
