· Subscriber
I'm looking for the aluminum piece that runs behind the control knobs on the dash from left side to the glove box. Mine is damaged beyond repair I think. It has some bad tears and dents. It's pretty flimsy stuff. The standard places (Donahue, Dearborn) don't seem to have a repo part or I'd spring for a new one.
-Will
64 Galaxie 466-520hp, C6-Transgo-stage-2-R-servo, 4"-Aluminum-driveshaft,
3:00-Strange-rearend Moser-35-spline-axles, 4 wheel power disc brakes,
resto-diary: www.math.byu.edu/~bill
<font size=-1>[ This Message was edited by: will4685 on 2/19/06 5:15am ]</font>
i have what you need... how good of shape do you want. i bought a swing-away dash from EBay to throw into my '64 500. both dashes have the same trim... not in 100% shape but can be buffed up. also, where are you?
· Subscriber
Utah. If the piece is not bent or dented, sounds good. Slight scratches I can buff out are fine. Sometimes the old aluminum pieces get corrosion under the anodizing which can be a pain to get out. PM me with any info.
-Will
