Anyone run one of these? Any thoughts? Currently I'm running a recurved Duraspark distributor, Mopar chrome ignition box, and jacobs coil. I'll either add the Jacobs computer box, or switch it all over to MSD or this DUI. Just wondering if anyone is running them and what they thought of it.
Thanks!
Pat
Where does the Mopar box fit in? Are you using the ford's pickup and the mopar controller?
Personally using MSD with duraspark pickup trigger.
I'm using the duraspark distributor, pickup and Jacobs Coil, and using the Mopar amplifier box. Works pretty slick actually.
First on my car i tried Jacobs. I could not get it to work sent it back about 2 times. The last time it fried my wires! It cost me about 300.00 to fix it. I would not suggest them. I have a DUI unit works flawless. Add alot of hp. I guess 30-40hp as advertised. Keep in mind i had points before. I went from .034 plug gap to .055 plug gap. Works realy good and cleans up your engine compartment. Hopes this helps good luck.
