Enough with the BS I am tired of fooling with diodes and relays and crap that doesn't work!!!!!!!!Imperial Hayes fan controller piece of S**T. i have the lincoln Mark 8 fan can anybody tell me if they have this fan what DCC Controler do you have. Thanks!!!!!!!!!!!!
Use a toggle switch to turn on a relay. The fan should be wired from the relay and NOT the switch. Make sure you use a GOOD higher amp relay. Those cheap Hella 30A relays usually only lasted me 2-3 months before they either stuck on (dead battery after running all day) or didn't work at all (overheat while sitting at a drive through).
Would you be able to tell me how to wire it up using a Bosch 75 amp power relay. Thanks for your help. Greatly appreciated. Thanks
