1 - 20 of 24 Posts
I've just purchased a reverse manual Performance Automatic valve body for my C4. It's an early 69 case. I'm looking at getting a deep pan now also. Is there a deep filter to suit the early filter style or am i going to have to make one? Anyone got any pics if they have made one.
i've seen that filter but it won't fit. It'll leave a gap on one side where it mounts. I've searched many threads and haven't seen anything for early vb's yet. Maybe if i make an adapter plate that goes between the vb and filter out of a piece of sheet metal. It'll basically look like a filter gasket in shape but extend on the section where the later style filter misses. Get what i mean?
I ran a filter I fabricated for some years with my first steel pan. I just very gently tacked a pc of tube over the opening on the filter and made it long enough to get where I wanted it. I then sealed it up with epoxy, worked well.
C-4's have screen so they are relatively easy to clean and reuse.
I do understand the feeling of putting a new filter on though.
<font size=-1>[ This Message was edited by: Mario428 on 3/18/06 7:07am ]</font>
i've narrowed it down to 2 options.
Option 1. As Mario stated above, tac on a tube to my standard filter.
Option 2. Using a piece of sheet metal, make a plate to go where the filter is. Cut a hole in it, add a tube. then use some sort of universal filter at the bottom of the tube.
Which do you guys recommend? option 1 is probably easier
Here is pic of your second option. This is a custom filter built by JPT. It was in a full on race C4 in a dragster. It might give you some ideas.
http://putfile.com/pic.php?pic=3/7606502661.jpg&s=x11
Grabber Green '70 Mach I 351C 4V 12.32 at 111mph
Robin Egg Blue '79 Fairmont 408C 4V 10.50 at 127mph
<font size=-1>[ This Message was edited by: clevelandstyle on 3/18/06 7:54pm ]</font>
Discussion Starter · #11 ·
i'm gonna go with my option 2. That pic from clevelandstyle is excellent and exactly what i had in mind. I'll use a torqueflight 727 gasket and pick up some steel this week. Hopefully have some pics in a week or two for everyone.
On 2006-03-29 12:06, gregaust wrote:
It's to suit an early valvebody type filter.
Thanks, I have a 68 casefill C4 and I am considering a deep pan (1" extra). Is that filter kit a special unit or a ford replacment part?
1 - 20 of 24 Posts
