41 - 56 of 56 Posts
Hello,
Could you please give me the diameter and lenght of the two interlock pins?
I rebuild my tranny and find out that no interlock pin is there.
I check on David Kee site but can't tell which one it should be. The tranny is from a '73 Mexican Sprint Mach 1, and when I look the rail kit it's not the 71/73 one I have, but 69 or 70, rail kit 4 or 5.
Shift Rail ID
Thank you,
Manu
Not uncommon for Mexican built Mustangs to use left over stuff from previous years. They were not built to meet the U.S. specifications or market.
I will look today to see if I still have a set of 69/70 rails and detents.
It would help me ID the detents that you need if you can post a photo of what you already have.
Hello Dennis,
Thanks for this quick answer!!!
With what you wrote I fill more confortable "Not uncommon for Mexican built Mustangs to use left over stuff from previous years", I was afraid to be stuck up with the tranny.
Here are a few pics hope that can help you to find out.
The pic helps a lot. I'll see what I can dig up today.
FYI, the parts you have ARE COMMON toploader parts, just for an earlier year than what would normally be in a U.S. 73. You should be fine once we determine which style detent you need. If nothing else, you can swap the rails and detents from any earlier transmission as long as they are a matched set.
It may have left the factory with a 73' toploader and someone swapped it out in the past due to damage. Any Mustang toploader from late 65-73 would bolt right in.
Out of curiosity, can you post a photo of the little tag that might still be riveted to the front passenger side of the main case and maybe the casting # found cast in the same case?
I found some numbers on the main case and the tail housing as well.
That's all what I have...
That is some pretty cool stuff that I have never seen before. Thank you for the photos. Does your car have a 351w motor? Again just curious.
Hello Dennis,
What you are missing is the interlock pin that goes in the 3/4 shift rail. Everything else look1 correct for a 1970 transmission.
Unfortunately I struck out. I looked at what I have left and only have a 70' reverse rail left. I've been building toploaders for resale and used the rest of the parts up, keeping the more desirable 65-66 big notch stuff for myself.
All may not be lost though as I compared David Key's photos to yours and came up that you have the 1970 Type 5 rails-look at how wide the machined flat area is between the notches in the top photo below. Compare that to your middle pic above. No other type rails are big and flat like that.
David Key also sells the correct interlock pin according to his web site.
Interlock Pin for Rail Kit
Type 5
$12.50
DK296-27-5
I found it here:
Interlock Pins
Hope that helps.
Exactly, this Toploader is connected to a 351W. All '73 Mach 1 Sprint came out with the Windsor engine.
About the interlock pin, I was thinking about the type 4 or 5. If you tell me 5 I trust you and will order it from David Kee.
I will come back for some news later.
Thank you for your help!!!
Hello,
I should receive the interlock pin next week. I cross my fingers.
At the meantime I found another Toploader, I just check it and it's a close ratio. No tag ID, cast number is C5AR-7006 D, so should be from 65/67.
The main shaft is shorter, so the tail house the same. This tranny is not complete.
Missing the top covers bolts 8 short and 2 longer, tail house bolts, drain and fill up plugs, and the short heavy spring, his blunt point detent and the screw on the top.
Type 2
If you have some of those parts, I will be interested.
Hello,
The tranny is rebuilt with the interlock pin. It seems to shift well. Was as well a training to rebuilt it.
I need now to order parts from David Kee then I will do the final and hope working rebuilt.
I will come back as soon as the trans is reconnected to the car.
Thanks for helping me.
Hello,
I need as well parts for the other Toploader.
Looks like it's the same setup as this picture:
What kind of detent is that on number one? (set screw), and number 2 (side bolt with short detent spring)? As soon as I know that I can order parts for both of my trannies.
It you rail set has the two "hatchet" detents shown in the middle, then you have the David Kee type 1 setup which uses 3 round detents. All 3 of the round detents are the same so your missing 2 will look like the detent shown on the bottom of the photo. The locations of the hatchet detents are important so don't mix them up with the round ones during installation
The short springs are all the same length/strength. One long spring from the later type rail sets can substitute for the bolt/short spring used in position 1 circled in the photo. The cover of the toploader then becomes the upper stop.
FYI, Type 1 is normally considered the most desirable setup (probably due to the hatchets having the most contact with the rail which helps ensure positive engagement.) Because I like them I have the type 1 rails and detents in all of my own personal toploaders as they can be used (as a complete set) in all cases up to 1973. Later cases can even be tapped for the bolt circled in the photo as long as you also use the short spring.
Actually the exploded view from DK site helped me cause it's the setup with hatchet detent.
So you are right, again. I read somewhere that this setup was the best made for our Toploaders.
I order for the early tranny:
2 short detent spring
2 round head detent
1 set screw
1 set of top cover bolts
Then to rebuilt the Mexican one I order the road race rebuilt kit.
Hope in 2 weeks the car will run...
The Toploader is almost done, all gears engage very well. Now need to install the tailhousing bushing, install all gaskets, then I will be ready to put it back to the car.
Come back while I finish.
After installation of the tranny, problems to engage all gears except the reverse. I could use it only if I was abusing of the shifter.
Well, I decided to remove the tranny again, and after a while I changed the shift tabs, drill the 3/4 with a new hole, reverse tab came to 1/2 gears.
And now it works perfectly.
Thanks for your help.
Manu.
Drilling the new hole in the tabs will make it physically harder to shift the gears. It won't hurt anything though. You might consider getting a new shifter. A Hurst Competition Plus would work perfectly.
41 - 56 of 56 Posts
