can anyone tell me how to connect the wires with eachother when i remove my dimmer switch?? im at work and it went bad so my lights keep shutting off until i put my foot on the switch but not pressing it then it turns back on...so i want to remove it for now and go without it until i get one....but how do i reconnect the wires? thanks!
If you are still here, either blast the hell of the underside with WD-40 and push it a few times hopefully or use a jumper wire to bypass it. Replace ASAP.
If i remember correctly, the center wire is the 'feed' wire and the two outers are the light(s) circuits for either the low, or the high beams, which ever way the switch is "toggled" internally.
But as Kult says R&R as soon as possible.....
If you bypass the switch and wire direct , please find the low beam wire so you won't blind on coming traffic, then replace the switch as soon as possible.
