I just did a front disc brake conversion on my 62 Galaxie. All went well until i tried to close the hood.
As you can see in the pic from the side that the booster and master are on quite an angle while the vehicle is relatively flat. This is obviously causing a clearance issue when closing the hood and I don't think it should be on that much of an angle. I just got the vehicle and am not sure if the previous owner had changed the booster or if it's stock.
Most of the replacement brake boosters i've looked at online look to mount quite square to the firewall.
Anybody know off hand?
It's a complete conversion front drum to disc kit from SSBC.
