Got a 79 F-100 with a 302 and want to swap engine to a 302 out of a 93 F150 will I have to change cam to be able for motor to run right with stock carb ?
I dont think your carb will be an issue. I dont know if the manifold will fit a late model 302 though. Im sure its close, but i just dont know 100% The carb will work, but may be lean. You would be better off to leave the engine alone, and invest in an intake and carb. Combos for a 302 from summitracing are "relatively" affordable.
