Pulled the skin off my Driver door. There was obvious rust in the bottom corners of the skin. Figured same inside as I saw pitting and some holes in the bottom of the frame or shell.
The door is actually very solid, except that front corner where the hing and corner brace are.
Cant find a patch panel to replace the corner, wonderng how tough this is gonna be, as its a long radius, AND on the 67 68 there is a bevel or step there where the door fits up into the jam. So fabricating this could be tricky.
Any hints or tricks based on experience? You know the difference, knowldege is gained from reading the manuals and research. Experience is gained from just jumping in and doing it, a couple of times. I have lots of experience now, need some knowledge.
I think someone ArnoldTX or some thread said they had to do this.
