Hi, can someone please give me advice on door hinge repair.I did search of forum came up with very little.I read that you have to cut pins to get out? is that right ? its easy enough to do.I was going to buy kit from dearborn with pins and bushing. hinges look real good but drivers side drops almost 1" when opening.Thanks don
One additional thing:
I read somewhere that if you drill a hole through both hinge halves with say a 1/8" drill bit before completely removing the hinge from the door and hinge post you can use these holes to reposition the door to the factory location. You might need two per hinge half.
Is this something anyone has done?
I have done this many times. Mostly when just R&Ring doors to jam or repair post. Also when doing hinges. When rebuilding/replacing hinges sometimes you may have to re-adjust a little because of the new bushing/pins. but not always, and even then it gets you close. And you do need 2 holes per side
Lou
