1 - 16 of 16 Posts
50/50 doesn't have anything to do with "stiff" - it's the percent of bias between extension and rebound in the shock. You should NOT use "drag shocks" on a daily. They are not made for it. Go get some Monroe's at Pep Boys for that. 50/50 in the rear and a 90/10 in front are OK for a weekend cruiser but don't expect great handling.
What have you got under the hood? What rear gear? What tranny? What kind of 60ft you hoping for? You may not need those shocks.
What stall converter? What are the details of the 349?
You may be fine with slicks and shocks that will handle well on the street. Adjustables are a good choice.
You might want to stay with your current shocks and run some slicks. I think you might be surprised especially once the caltracks are dialed in. Even a set of M/T drag radials might do.
If you're buying Caltracks, get the recommended Rancho 9000s for the rear. For an occasional, the 90/10 won't make much difference to you but will at the strip. I put adjustables on mine years ago then got lazy and just left it at 90/10. I still take the occasional drive. With a good front end setup (poly, fresh parts, etc) you can even do without the sway bar.
I had a set of custom QA1 coil overs made up for my Bird, and love them. They are adjustable, and gi from 50/50 to 90/10. I have driven it around town at 90/10 many times with no front sway bar with no problems. Would not do any high speed mountain driving like that, but it is fine for normal driving.
Yep, front drag springs work best when there are more coils, but a lesser lb per inch rating. I use 250 lb for normal streer driving, and will be using 200 lb for strip use. These are 14 inch long springs.
1 - 16 of 16 Posts
