I was able to jack up the car and places two jack stands on the side. I noticed that there's no screw or plug for the engine oil. Did I miss something? Am I not looking in the right place? How do I drain it?
Thanks!
First I wish to mention this.... no older Ford has an oil pan without a drain plug. Or at least, I've never heard of it.
Second, mention which engine you have and someone might be able to tell you exactly where that plug is.
Lastly, make sure you aren't looking at the transmission pan.
^^^+1^^^:tup:
There will be a cross member running under the engine, the oil pan is directly above the cross member, the drain plug will either be in front of or behind the cross member.
