Will be puting my pan fill trans back together later this week, need to know how much fluid to put in ? I need to get close as I am going to put a new engine in at the same time and will be concerned with cam break in and tune would like to not worry about trans till I get the engine set up.
Put in 3 quarts and forget about it until the cam is broken in.
The tranny, while in park, won't burn up on you. Just don't try to move the car.
and be sure to give the coolant system time to fully bleed before firing it up. I fill them from the upper heater hose with a funnel leaving the rad cap off and waiting until the heater core fills up then the fluid passes through the waterpump and heads and there is only coolant coming out and no more air. Then I put the hose quickly on and fill through the radiator to top it off.
FE
