Here's the dyno results for my 331 that's in my 93 Mustang Cobra.
DSS 331 Short Block
AFR 185 non-emission heads w/upgraded springs and titanium retains
10.8 to 1 compression
Comp Cams XE274HR cam
Holley EFI Intake
30lb. injectors
255 LPH fuel pump w/ 100 octane Sunoco GT100
Pro-M Bullet Air Meter
70mm Throttle body
BBK 1 3/4" Dia. full length headers w/2 1/2" Bassani X-pipe and Mac Pro-Dumps
TKO w/3.73 gears
Baseline run was 345 RWHP.
Custom SCT tune by Jerry Wroblewski netted 380 RWHP/380 RWTQ.
Chart shows 375 RWHP, this was the last run as timing was being added 2 degrees at a time.
http://pg.photos.yahoo.com/ph/tcgrmt/detail?.dir=897b&.dnm=4c4b.jpg&.src=ph
That's near 450hp/tq at the flywheel, awesome work!
Can't wait to get my 347 going and see how it does.
Cris
Dang that's nearly 395HP at the crank with a T5. Not bad!
Hmm, did I miscalculate that? lol. I started around 475hp and subtracted down 15% until I reached his numbers lol. T5/8.8's about 15% horsepower loss correct? Even adding 15% to his number I still come up with like 435+ hp or so.
Hmm....
