Does anybody have a simple wiring diagram for a conversion from point ignition to a Duraspark Ignition.This should be a good conversion seeings how thers millions of them out there.
It is a great converstion. The best solution is to find the wiring harness that connects to the ignition box to the distributor/coil, a coil for the clip-on bracket, and the distributor. Otherwise you have to chase the wires and cut connectors off or splice connectors.....too much hassle.
If you have all those items, then connect the original iginition wire that connected to the coil to the red wire of the other plug.
