I'm hooking up a Duraspark II box to my MSD distributor and Blaster II coil to temporarily eliminate the MSD 6AL box in an attempt to isolate a real obscure ignitiion problem. When hooking up the 12V Duraspark box (red wire) to the ignition switch, what size fuse (if any) should be put in the circuit? Also, I intend to use #14 gauge wire unless someonw thinks that is too light.
