i was given a C4 with part # C5AP 7006 C is this a "green dot shift pattern? Were all early C4s this type of shift pattern, if not how can you tell the difference between that and a standard shift?
Any help would be appreciated
All american c4's were until the 67 model year.I just changed mine over to the normal shift pattern.Here any 67-69 c4 valve body will do the conversion.70 and newer will not fit.It needs to begin with a c7ap part# to be the standard shift.
