I have the spindles and rotors from an 87 and up stang plus a set of 73 mm calipers with a master cyl from a 84-86 SVO mustang. have yet to purchase the 87 and newer struts(thinking 70/30 lakewoods). Any tech tips or other parts I need to install this on an 81 stang? Any websites out there with this install shown? These calipers look bigger then the stockers do 15 inch wheels clear these things? Specificly a set of 15 x 4 centerlines?
Thanx for any info.
Tim
I think you can use your struts if you fabracate a shim or use washers.On the spindle where the gap is with the strut installed on the spindle.
