would it be a bad idea to do an efi swap into a 65 mustang using a 351W setup from a 93 ford truck? i know the intake is a bit high. could i use the upper intake from a 5.0? will it plug into the truck harness? could i use the truck harness and computer? what do you guys think?
Are you planning on a 5.0 swap using the truck electronics, if so bad idea. Except for the Lightnings(Lightning would be good) the trucks use a batch fire injector setup, it doesn't accept engine modifications very well. The best system is the '89-'93 Mustang setup.
