Well said Qtrhors...
The Torker II 351W is not a bad intake, the Torker II 302 is junk in my opinion. I used one years ago, and didn't care for it.
For under 6500 rpm usage, it's tough to beat today's large capacity dual planes... (Performer RPM, Air Gap, Stealth) These are good units. I've also had good luck with the original Torker 289. The Weiand Accelerator is pretty much the same thing. These work well, and can often be found cheap... which is a quality overcoming many faults.
Smooth the plenum into the port roofs with a grinder for best results using these intakes. Spacers are good too. These, along with the old Offy Port-O-Sonic (289-302) are about the only 'old' intakes I'd use on a 289-302. The Offy, with a little blending to the plenum, can be a serious contender. As for the rest of the Offy line, forget it!
Good Luck!
Mike Burch, 66 mustang real street
302 4-speed 289 heads, 10.63 @ 129.3
http://www.geocities.com/carbedstangs/cmml_mburch.html
http://www.fortunecity.com/silverstone/healey/367
<font size=-1>[ This Message was edited by: n2omike on 2/20/02 2:40am ]</font>
