1 - 19 of 19 Posts
Is it worth swiching from eec-4 to eec-5?
If starting from scratch, should I go after a harness and eec5 from an 97-98 explorer or just go get a harness/computer from a 5.0?
Any advantges of using the eec5??
yeah i would like to know also?
Yes, I'm in the middle of a EEC-V equipped engine project.
Why do you want to change to EEC-V?
The general answer is: NO!!
But feel free to ask questions
Doc
So there are no advantages to eec-V??????????
But you are using 5 instead of 4??
Yes, it is advantages. The 5 is a big development from the 4. But to go through a changeover from 4 to 5, with all the money and job involved to do that, I'll say it isn't worth it. The 4 does the job its intended to do in a great way, if it's tuned/chiped correctly. If you are going to change the whole thing (engine/transmission/EEC), then it's worth it. To do something everybody hasn't done yet is always worth whatever it takes.
The only time the 5 should be used (IMO), is if you are going to use an engine wich came originally with the 5. The 5 supports distributorless ignition, coil packs/coil over plugs and SEFI. I don't think you'll find any 4's that do that, so it'll be a massive electric/electronic rebuild. Ask me, I'm up to my knees in wires.
Doc
<font size=-1>[ This Message was edited by: Doc on 1/4/03 3:04am ]</font>
Hey Doc, the '92-'95 4.6 engines are DIS and still use the EEC-IV system. Also the early '90s 2.3 4cyl in the Mustangs & Rangers run a dual plug DIS system using the IV system.
1988 Turbo Coupe...5.0 Conversion
NA [email protected]/90 Shot [email protected]
<font size=-1>[ This Message was edited by: TurboCoupe50 on 1/4/03 2:47am ]</font>
No problem Doc, I magine a lot of the American models are kinda scarce over your way. Also I forgot, the DOHC Mark VIII Lincoln 4.6 has the EEC-IV system '93-'95.
Yes, thats right. VERY scarce.
And here in Europe, the EEC-V didn't come until 1999-2000. We are a little behind in certain areas.
But that don't stop me from using an 1999 Intech 5.4 DOHC in my project. It's going to be interesting.............but not frustrating I hope. I'm learning as I go.
Doc
The V also was required to use with the electronic controled transmissions, and to monitor the cats. Thats where the 2nd set of O2 sensors comes in.
Maybe you should look at the Ford Racing Xtreme EFI, completely programable from a PC/laptop. It replaces your eec-iv and a new one for eec-v
Begnning with the '87 automatic Turbo Coupes, there was some transmission controll in the EEC-IV systems(overdrive and converter lockup). In '92 EEC-IV systems were preformng all the shifts in the AODE automatics (Crown Vic, Grand Marquis and Town Car).
Where can I get this and have you used it or know someone that has used it? Thanks for any info.
EEC-V is OBD-II. I great system for stock type cars but makes it harder to modify
( read that as more expensive). It is when all the manufacturers got their computer systems "talking" the same language. If you can fix a Ford, you can fix a Toyota.
EEC-V was strictly designed for OBD2, as a result because the EEC needed to monitor misfire they moved all the ignition control onto the EEC. Earlier EEC-IV that had DIS or EDIS used individual ignition modules, first with DIS which required no real programming changes from TFI, and then EDIS which requires a certain EEC-IV computer to run due to the Programmed pulsewidth SAW signal peculiar to EDIS, which is diferent than the TFI or DIS SPOUT.
This is in addition to the requirement to monitor Cat converter performance, as required by OBD2 as discussed earlier.
The biggest issue, at least from what I've heard - is the EEC-5 w/OBD-II was also the beginning of management computers being "snitch-enabled". It can read back what was happening as far as engine management, anything else it controlled, directly. The previous versions eec-IV were, more or less, restricted to accumulating codes.
Not all that important in a hobby, modified, upgrade use - but I just find it "spooky" that, after the fact it is possible to reconstruct how fast you were going, when you applied braking and much longer, extended ability to collect detailed data on any changes made to the engine.
Is this fact or fiction?
It just takes time for the information to filter down. The more complicated the Technology, the longer it takes for the average Joe to absorb it, then a little longer for us to figure out what is important, good to know or just in the way. ;)
Ford Vehicles: Help - Glossary
1 - 19 of 19 Posts
