I have a 408,roller block, w/EFI,92 Mustang harness,C3W computer. The engine is on a dyno. It started about 3-4 times with about 12-14 degrees of timing. Now you have to move the distributer to about 25 degrees to get it started. The engine has no belt system (water pump is run by electric motor) and is using a battery for power. No significant coputer codes. CAN ANYONE HELP ME?
try resticking the dist.maybe it's a tooth off.is the spout connector still removed??
pip sensor bad?? TFI module going bad??
just throwing stuff out there...good luck
maybe it's as simple as not having enough juice from the battery
low 12 sec. '95 F-150....lookin' for 11's soon
<font size=-1>[ This Message was edited by: noslofoord on 1/25/02 10:20am ]</font>
