Just kinda curious, what would be the easiest wayto retro my '85 f-250? i can pick up a complete '94 f-250 for little of nothing (damn tree jumped out in front of it
) and it's got a 5.8 efi engine. is there a way to do this swap with the factory harness? or would i be better off with a harness from wnidsor-fox?. if i do this, it will remain bone stock, as this is going in my daily driver.
anyone got any opinions?
Should be fairly straight forward since your using a donar vehicle, get the ECM, Harness and 5.8 w/ EFI You will want to use the trans and wiring for it. Also the 94 may have a speed sensor on the rearend if its not on the transmisson. Get that and the gas tank from the 94 with the Electric pump.
