There are 3 options for EGR block-off in the GT40 intake. You can:
- Use intake gaskets that have exhaust crossover blocking pieces, such as the Fel-Pro 1250.
- Plug the passage at the top of the lower manifold with a core plug (freeze plug) or tap and plug.
- Remove the EGR and make or buy a simple plate to block the passage.
Notice I ordered them 1-2-3, as that is the preference. Each successive method allows heat farther up into the manifold, and that's not good for power. However, if your ECM will control the EGR properly, deleting it will result in lower mileage and you may also get some mid-range detonation. EGR benefits both of those. While often considered an 'emissions' device, it's primary function is actually mileage and efficiency. Folks often think it's for emissions, as a secondary side-effect is to cool the burning charge to suppress detonation, and that coincidentally causes a reduction in NOx emissions.
If someone asks what EGR is really for, tell them straight - it's to reduce pumping losses at part throttle and increase dynamic compression at cruise, while suppressing detonation from greater ignition advance for efficiency. :tup: Taken a step further (not for the average street car), you can slightly richen your cruise to make more CO (carbon monoxide) instead of CO2 (carbon dioxide) and run more EGR, burning at high compression or boost without det - as it's actually running mostly on CO. The air and fuel are just added to generate CO that is then burned by the engine. CO is a powerful and very high octane fuel. Audi is testing a 4-cylinder street engine that produces over 450 hp on 70% EGR. Mileage is a secret, but indicated that it's very high.
Anyway, I'd also say the 30# injectors are overkill, as 24s will handle 340 hp. No reason to reduce your low-speed control with flow you can't use. Run the math and take your pick:
InjectorSize = (HorsePower * BSFC) / (#Injectors * DutyCycle)
So, (340*.50) / 8*90) = 23.6#
This would allow a large stock MAF such as the Explorer, Cobra, Lightning, or Lincoln units along with common data files for chips or burning. But it's up to you.
