so what are the benefits of this?
1: the typical thermal spike after shutdown causes cooling system pressure to rise. this basically eliminates that. Its easier on gaskets, and the heater core, hoses, etc.
2: removes any possibility for vapor lock.
I have some technical points I could make about how that convective heating and cooling occurs, but that isn't the point, as it is not a problem. The point of this is not how one should do something, but why. Problems require diagnostics, and that is fact-based. It's your ride so do as you like, and if it's just really neat for you to hear fans running as you walk away, that's a valid reason and I say do your thing! I respect reasons, any valid reasons (if you think it's cool, just say that and move-on), but soft rationalizations don't do anything for any of us.
Your two points do not answer any problems you have, or should have. The point #1 thermal spike is normal (heat soaking of the relatively stagnant coolant in the engine and sensor), but pressure should not rise to above the max operating pressure, as per the Ford Shop Manual (FSM). Pressure issues with gaskets, cores and hoses should not ever be present in a properly functioning system. If it does get to higher than FSM spec pressure, you have to wonder why and fix that first, and has nothing to do with E-fans. Our cars without electric fans don't need that, so why yours? Electric fans would be a band-aid to a more basic issue that needs attention. After all that, what is after-run solving for you, really?
Same goes for #2. Vapor-lock is not a standard condition, and should not occur with electric fans or not. What should non-E-fan owners do if they can't run the fan to "fix" the issue? Ah, fix the root issue rather than another band-aid to work around it. If there is no initial vapor-lock issue, there is no need for after-run fans. Problem solved and no gain to after-run, for that reason anyway.
So while I had no intention of magnifying this portion of the conversation, I hope you can see that we sometimes need to step-back and verify we are doing things for valid reasons, in this case electric fans and their operation. We can see where diagnostics is taking us, and this can guide our choices to quicker, easier, more effective or less costly alternatives, if we are not barking up a reasonably-sounding but rationally misplaced tree. This results in simpler and often better solutions, rather than bigger cooling systems, after-run fans or costly ethanol-free fuel, etc.
For example, more than half
of the "overheating" issues I've solved over the years were not actual overheats, but bad info from a gauge, or overfilling, with owners at wit's-end and hundreds or thousands in the hole over almost nothing. Do as you wish, I can't have any issue whatsoever with that and I am not drilling anyone, but rather having a conversation about getting there from here on a solid and productive happy path.
