So after starting the 63 up a few times and fixing the gas tank leak i started to install oil/water gages and screwed the instrument/spedometer cluster back on. went to start her and "click,click, click...."
The only wires i had moved/touched were under the dash. What would cause the car not to start and behave this way? I can her the starter solenoid make the clicking noise but engine isn't turning over.
could i have moved a wire that is causing it to short out, would this create this?
Kevin
Kevin
